Telecom Data model
7460
7
02-17-2016 06:59 AM
OlegLukyanov
I look for Esri Telecom Data model (data dictionary, template GDBs, UML, etc) August 2007 or later (not Fiber optic only).
Links from
http://support.esri.com/en/knowledgebase/techarticles/detail/40585
http://downloads2.esri.com/support/TechArticles/Telecommunications_Data_Model.pdf
http://www.arcgis.com/home/item.html?id=0ab9a0e3261045e5ac2df30ec3cd7b1b
are dead .
Help please.
P.S.
Many other data model's  links are dead also.
MikeMillerGIS
Esri Frequent Contributor
You can find the Telecom datamodel here: Fiber Network Data Model | ArcGIS for Telecommunications
NurkuisaRametov1
How I will download the data model from this resource? @MikeMillerGIS  can you attach xml file?
Thank you!
MikeMillerGIS
You can find the current models here
https://doc.arcgis.com/en/arcgis-solutions/latest/reference/introduction-to-communications-utility-n...
and
https://doc.arcgis.com/en/arcgis-solutions/latest/reference/introduction-to-communications-data-mana...
We are working on a blog that compares and contrast the two different solutions.  I will post an updated here with the link once it is posted.
CherylTrine
Has the comparison between the Communications Utility Network Foundation and the Communications Data Management been posted anywhere yet.  I can't seem to find it and I'm trying to figure out which one to try to implement.
Thanks
RajaIjazHaider
Fiber Utility Network Management (FUMS) uses fiber specific dataset, which carry great knowledge harvesting from existing fibre management tools. https://enterprise.sitdigital.com/storymap/
RajaIjazHaider
RajaIjazHaider
