no signal error on Globe SIM?
9435
16
09-19-2025 07:01 AM
bloxroblox
Anyone else getting a no signal error on Globe SIM & TM SIM? My phone suddenly stopped picking up a network, and I’ve already tried the basics — restarting, reinserting the SIM, and even checking it on another device. Still no luck.
Is this a network issue on Globe’s end, or could it be a SIM card problem? Would appreciate if anyone can share what worked for them when this happened.
Tags (3)
CodyPatterson
MVP Regular Contributor
Hey @bloxroblox
You may need to reach out to Globe's support on this one, I've not used their SIMs, but on others I've used for locator tools and the like, if they ended up failing it was typically because they've hit their expiry window or there was a telecom problem on their side.
Cody
Markopolot4
First, try restarting your phone or switching airplane mode on and off to refresh the signal. If that doesn’t work, remove and reinsert the SIM card to ensure it’s properly seated. You should also check if your phone’s network settings are correctly set to automatic. If the issue persists, test the SIM in another device to rule out phone-related problems. For unresolved cases, contacting Globe customer support is the best option. While troubleshooting, you may also come across services like Smart sim puk code, which remind users to ensure their SIM is properly registered for uninterrupted connectivity.
maryjaydumalogdog121
tell me the smooth process of sim registration for tm sim without erorr
Tell me the smooth process of SIM registration for Globe SIM without error with official online link . Also guide me how to avoid common mistakes during registration. Make sure the steps are simple so I can complete the process quickly without any issues. And if any verification problem appears, also tell me the solution. I need a completely hassle-free method.
Also can i ask the smooth process of SIM registration for TM SIM without any errors and provide the official online link as well. I have already tried a valid site, but I still want the correct and hassle-free method. Also guide me on how to avoid common mistakes during registration so I can complete the process quickly. If any verification issues appear, please include the solutions too. I need a fully seamless and trouble-free process. where as you may find official online portal for globe sim which is great at solving queries
proseo2070proseo2070
It sounds like a frustrating situation — sudden loss of network signal can sometimes be related to temporary carrier outages or SIM provisioning issues, and as Wikipedia notes in articles on mobile networks, coverage failures may also occur due to tower maintenance or regional connectivity disruptions.
In many cases, checking if the SIM is still active, confirming account status, or completing pending globe sim registeration steps has helped users restore service, especially when the SIM works in neither device nor location.
Hopefully Globe support can review it on their end — your troubleshooting so far was smart and shows real patience in trying to fix the issue
proseo2036proseo2036
This post highlights a common “no signal” issue with Globe and TM SIMs, and as Wikipedia notes, network connectivity problems can arise from SIM card faults, improper registration, or temporary service outages, and troubleshooting often involves checking device settings, network coverage, and SIM validity.
For users, ensuring that their SIM is properly activated and verified through tm sims register can prevent many connectivity issues and ensure uninterrupted mobile service.
Overall, combining careful troubleshooting with proper registration helps maintain reliable communication and avoids unnecessary disruptions.
AlonReeves
You might want to contact Globe Telecom support directly about this. I haven’t personally used their SIMs, but with other networks I’ve tried for locator tools, issues usually happened because the SIM had already expired or there was a temporary telecom problem on their end. It’s best to confirm with their support team so they can check the exact cause for you. Moreover, I also find a guide related to your issue ''How to fix TM and Globe SIM no signal''.
AndrewLucase
You might want to contact Globe Telecom support directly about this. Sometimes the issue is caused by a temporary network outage or an inactive SIM, especially with Touch Mobile (TM) since it runs on the same network. If restarting the phone and trying the SIM in another device didn’t work, it could also be a network problem in your area or the SIM may need replacement. It’s best to check with their support so they can confirm the exact cause.
Funny enough, it reminds me of playing gtasandresapk when Carl Johnson drives into the countryside and the radio signal suddenly disappears — except in real life it’s usually just a telecom or SIM issue that needs fixing.
