Having Trouble Using CoverageProcessing Tool.
958
03-08-2019 08:43 AM
BatuhanMekiker
Hi!
I don't know if I'm in the right place to ask this, if I'm not please redirect me to a source or a discussion board. Thanks!
I'm trying to use CoverageProcessing tool but having problems possibly with the data set. I wasn't able to get it working with example dataset either. I'm selecting the example input raster, reclassify values using the RecordSet provided in the example database. Then setting the 1st resample to half of the resolution which is 50 for both X and Y. Finally creating an output feature class and setting the vertex limit to between 10-20. Process takes about 10 mins and giving an output error like this:
Executing (Make Feature Layer): MakeFeatureLayer C:\Users\f15j375\Documents\ArcGIS\scratch.gdb\dissolved_0 "Feature Layer 1" # # "OBJECTID OBJECTID VISIBLE NONE;Shape Shape VISIBLE NONE;Id Id VISIBLE NONE;gridcode gridcode VISIBLE NONE;Shape_Length Shape_Length VISIBLE NONE;Shape_Area Shape_Area VISIBLE NONE"
Start Time: Thu Mar  7 16:14:21 2019
ERROR 000229: Cannot open C:\Users\f15j375\Documents\ArcGIS\scratch.gdb\dissolved_0
Failed to execute (Make Feature Layer).
Failed at Thu Mar  7 16:14:21 2019 (Elapsed Time: 0.01 seconds)
Failed to execute (Eliminate Selection).#
Failed at Thu Mar  7 16:14:21 2019 (Elapsed Time: 8.68 seconds)
Failed to execute (Process Vector).
Failed at Thu Mar  7 16:14:21 2019 (Elapsed Time: 9.43 seconds)
Failed to execute (ProcessSignalStrength).
Failed at Thu Mar  7 16:14:21 2019 (Elapsed Time: 9 minutes 34 seconds)
