Communications Utility Network Foundation (Esri)
49309
74
09-22-2017 09:00 PM
SpatialNinja
The Esri team is continuing to refine and improve the data model for comms data management on ArcGIS Utility Network Management. Use this thread to provide input on the requirements of the data model, capabilities of the telecom network, ask questions about the network, access early versions of data models, and stay up to date on the latest news.
Communications Utility Network Foundation (Story Map)
Communications Utility Network Foundation Workflows (Story Map)
PNI ModelsStatus Last UpdatedSoftware Requirements
Fiber, Coax, Copper, WirelessVersion 1.3 Released November 20223/27/2023Introduction to Communications Utility Network Foundation - Requirements
Join the Discussion Below!
- Esri Telecom Team
 telecominfo@esri.com
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
SpatialNinja
Ericsson's Network Engineer (ENE) and Esri
If you have questions about logical migration paths from Ericsson's Network Engineer (ENE) to other Esri solutions, please contact us at the email or number below and we talk through available options. There are plenty of options for supporting your network management and PNI needs.
Contact Esri at Ericsson_Esri@esri.com or US Toll Free 888-447-9706
FIDEL OMAR-ALIIñaki Lázaro CanteraRajesh Mane
#ENE #Ericsson #Network Engineer #ArcGIS
BrettLessner_Nsight
Are there any details about copper vs fiber with this new network? Although new copper construction is almost nonexistent for us, we do have a substantial amount of both copper and fiber in our network. We model copper the best we can with the current fiber model, but there are limitations. Will the new data model be fiber-centric or will it be more flexible?
Please share a link if this discussion has already been had.
SpatialNinja
New FAQ doc for the utility network: https://community.esri.com/docs/DOC-13144-utility-network-technical-faq
FIDELOMAR-ALI
Is the new release of Utility Network available and able to support Telecommunications network infrastructure yet?
If not, what is the ETA for this to happen?
Thank you.
SpatialNinja
Early preview of the fiber data model asset package and telecom symbology set has been attached to this thread for download and feedback. Please note this is an early preview and for comments and feedback contact please reply to this thread.
SpatialNinja
New blog outlining options for network management in ArcGIS: https://community.esri.com/community/telecommunications/blog/2019/08/05/network-transformation-a-str...
MatthewDowning2
Is there any documentation on which versions of Enterprise, Pro, and Asset Packages play well with each other? Any dependencies etc. For example can the early preview of the fiber package work on 10.6 and Pro 2.4
SpatialNinja
Highlighted a connected trace in the Utility Network at the 2019 Esri GeoConX leveraging the early release of the fiber asset package. Watch the video here:  Patrick Huls on LinkedIn: "Lots of great conversations at Esri GeoConX around fiber planning & manag...
SpatialNinja
What’s New in the April 2020 Early Preview:
  • New network management levels or tiers (National, Regional, Distribution, Access, Drop & Indoor)
  • Added support for point structures: pole, handhole, pedestal
  • Added support for line structures: aerial span, wire trench
  • Added ability for structure containment of communications domain, ie. aerial span to contain fiber cable
  • Added support for defining in and out ports on network equipment
  • Added splitter device support (Split Ratio: 1:4, 1:8, 1:16, 1:32 & 1:64)
  • Added strand management for fiber cable
  • Added association rules to associate fiber strand to available ports
  • Added editor templates for common fiber cable types and equipment
See whats new in action:  Video Link : 6140
José_JoaquínMuñoz_Villarreal
Hi Patrick:
When will we have an Asset Package available?
Thanks!
