HELP!
821
11-18-2016 08:16 AM
BrandiLeRoy1
I have a student trying to work on a project and we can't get this map to work.  His information from his attribute table will not show up in his pop ups.  I have played with it but can not figure out what is going on.  Please help.
http://arcg.is/2f7M0j8
CharlieFitzpatrick
Esri Alum
Hi Brandi, I was able to view the map, open the table, see the 6 features with large amounts of info in the attribute table, go to the layer and configure the popup but the nature of the attributes are, I think, causing a little issue. When I went to configure the popup, I saw a little counter showing which fields are being displayed, and it was set to 0. When I changed that, and changed the title to show the country, and configure the popup so show manually, I could see the content. I think it is expecting a modest amount of text in each cell, and there are some cells with quite a lot, including commas, which may make it have a little trouble. But I was able to get a display even while just on my iPad. Look for a counter (spinner) in the left column of the configure popup zone.
