Zoom to location
3976
6
03-30-2023 06:33 AM
GBreen
I'm really liking the new SwiftUI implementation but I'm having trouble with one thing. I have a button to zoom to the current location. In order to do that I set a viewpoint and it works the first time. But if I move and try to tap it again it doesn't zoom. The workaround is I watch the viewpoint for changes and set it back to nil immediately. Is this the best way to implement zooming or is there some other way to do it? I can't find anything in the docs for it. Here's the example code:
struct MapZoomTestView: View {
    @StateObject private var map: Map = {
        let map = Map(basemapStyle: .arcGISTopographic)
        map.initialViewpoint = Viewpoint(latitude: 34.02700, longitude: -118.80500, scale: 72_000)
        return map
    @State var viewpoint: Viewpoint? = nil
    let locationDisplay = LocationDisplay(dataSource: SystemLocationDataSource())
    init() {
        ArcGISEnvironment.apiKey = APIKey("")
    var body: some View {
        MapView(map: map, viewpoint: viewpoint)
            .locationDisplay(locationDisplay)
            .task {
                let locationManager = CLLocationManager()
                if locationManager.authorizationStatus == .notDetermined {
                    locationManager.requestWhenInUseAuthorization()
                do {
                    try await locationDisplay.dataSource.start()
                } catch {
                    print("Current Location Cannot Be Shown")
            .overlay(alignment: .bottomLeading) {
                Button {
                    guard let location = locationDisplay.location else {
                        return
                    viewpoint = Viewpoint(center: location.position, scale: 10_000)
                } label: {
                    Image(systemName: "paperplane.fill")
                .frame(width: 50, height: 50, alignment: .center)
                .background(.regularMaterial)
                .cornerRadius(25.0)
                .padding([.leading, .bottom])
            .onChange(of: viewpoint) { newValue in
                guard newValue != nil else {
                    return
                viewpoint = nil
            .ignoresSafeArea()
rolson_esri
Esri Alum
What you have works with the beta release. As you have noticed, this isn't ideal.  Final (200.1) should be released soon and there will be a much better way to achieve what you are looking for via a MapViewReader and the associated proxy:
        MapViewReader { proxy in
                .task {
                    do {
                    } catch {
                    Button {
                            return
                        Task {
                            await proxy.setViewpointCenter(location.position, scale: 10_000)
                    } label: {
                    .cornerRadius(25.0)
                .ignoresSafeArea()
Note: the call above that sets the viewpoint (`proxy.setViewpointCenter(:scale:)`) will actually animate to the new viewpoint.  You can tell that because it's an async call. There will also be an un-animated setViewpoint function on the proxy once we release 200.1.
DuanePfeiffer
I accomplish this by setting the locationDisplay.autoPanMode.  Not sure if that is your desired outcome or not.
        appData.locationDisplay.autoPanMode = .recenter
GBreen
Yeah I thought about that too but then the map follows the user where I just want them to be able to decide when to zoom, not auto pan. I could do something like below but that seems just as hacky
locationDisplay.autoPanMode = .off
GBreen
Also I would like a solution that can be used to zoom to other geometries as well, not just the current location if that makes sense.
rolson_esri
Esri Alum
                .task {
                    do {
                    } catch {
                    Button {
                            return
                        Task {
                    } label: {
                    .cornerRadius(25.0)
                .ignoresSafeArea()
GBreen
Oh Awesome! I'm already using the MapViewReader for and identify operation so that will be super simple to implement. Thanks!
Ting
by Esri Regular Contributor
With the 200.1 release, we have a Change viewpoint sample that shows this API. 🙂
