Set the Image Size in a Popup
2224
08-20-2025 12:54 PM
RTC
Hi, I'm looking for a way to control the image size that is displayed within a Popup using Esri 200.8.
Currently the image looks like it is getting rounded corners and the image itself is being cropped off. Can this be configured in AGOL?
Thanks!
Leena_Abdulqader
Hi @RTC, AGOL automatically resizes the image to fit the pop-up's layout. To optimize display, I think it is recommended to use images with a width around 400 px; anything less may show borders; anything significantly wider might be auto-rescaled and appear distorted. The ideal aspect ratio for a panel pop-up is typically 4:3 (e.g., 600×450 px). Unfortunately, rounded corners or cropping are dictated by the default theme and cannot be disabled or adjusted via the UI.
Check this  https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/configure-pop-ups-tips-photos?utm_so...
Someone said he used Arcade, but I've never tried that https://community.esri.com/t5/arcgis-online-questions/resizing-images-in-arcgis-map-viewer-pop-ups/t...
I hope this helps.
RTC
Thanks for the reply Leena! I am looking into the option of Arcade but it's not ideal, was hoping there was something in the SDK.
Thanks!
DavidFeinzimer
Hi @RTC, thank you for reaching out. This isn't a customization currently supported at either the AGOL or SDK/toolkit level. The static size and rounded corners with cropping are as-designed. In the short term, the quickest resolution would be to fork the toolkit and customize the component as desired. Long term, if you're looking for more control over element appearance across different platforms at the authoring level, I would encourage you to file this as an idea in the ArcGIS Maps SDKs Native Ideas board.
David
RTC
Thanks David for confirming that is it not customizable.
