Resize floating panel by dragging anywhere on its surface
1249
09-23-2024 12:47 AM
mmoosbac94
Hello everyone,
is there a way to enable resizing of a floating panel by dragging anywhere on its surface, similar to how it's done in Apple Maps or Google Maps? Currently, it seems that the Swift SDK only supports resizing via the small handle rectangle, which can sometimes be difficult to interact with.
In some cases, it would be much more user-friendly to allow resizing from anywhere on the panel. Any suggestions or improvements to achieve this would be appreciated!
Thank you!
Marvin
DavidFeinzimer
Hello Marvin,
Thank you for reaching out. The component doesn't currently support the functionality you've described, but this is excellent feedback that helps us drive future enhancements. I've created an issue in the Toolkit repository to document your feedback and track progress on the enhancement.
Cheers,
David
DavidFeinzimer
Hello Marvin,
Cheers,
David
mmoosbac94
Hello @DavidFeinzimer,
sounds good! Thank you very much.
Cheers,
Marvin
