Memory Leak when update ArcGISURLSession
2323
6
01-20-2025 09:59 AM
ByronAndres
We enable on our app the use of cache for the maps views, so we are using the following code to activate this option:
        ArcGISEnvironment.urlSession = ArcGISURLSession {
            let defaultConfig = URLSessionConfiguration.default
            defaultConfig.requestCachePolicy = .returnCacheDataElseLoad
            return defaultConfig
While analyzing the app in Profile mode on Xcode, we noticed that this configuration causes a memory leak each time the map is loaded. Below is the error displayed in the Xcode Profile:
Screenshot 2025-01-20 at 11.54.44 AM.pngScreenshot 2025-01-20 at 11.52.20 AM.png
We would like to confirm with you whether this is the correct way to set up the cache configuration. Additionally, do you have any insights into what might be causing the issue with the map when it loads for the first time?
Tags (4)
RyanOlson1
Does this occur more than once per run of your app? If so, how much memory is leaked in a typical run of the app?
ByronAndres
Hi @RyanOlson1 This occurs each time a screen with the map is loaded, which means it can happen multiple times during a single run.
RyanOlson1
Why do you need to set the URLSession every time a map is loaded?
ByronAndres
Apologies for not explaining the issue clearly. We only set up the URLSession once, but we observe a memory leak every time we open the map.
Destiny_Hochhalter
Hi @ByronAndres,
Can you include a minimum reproducible example via a code snippet or project that sets the ArcGISEnvironment.urlSession configuration and loads a map? I am able to reproduce the memory leak.
ByronAndres
Sure, I'll send you a direct message with the code where we reproduce this memory leak.
