InvalidArgumentError(details: "Mobile map directory path is not an empty directory.")
952
02-11-2025 08:05 AM
MuralikrishnaDanthala
I am getting above error while try to load offline downloaded map
below is the code snipet
 Folder structure Folder structure
import SwiftUI
import ArcGIS
struct OfflineMapViewDetails: View {
    @State private var offlineMap: Map?
    @StateObject private var offlineMapTaskWrapper: OfflineMapTaskWrapper
    var itemId: String
    init(itemId: String) {
        self.itemId = itemId
        _offlineMapTaskWrapper = StateObject(wrappedValue: OfflineMapTaskWrapper(itemId: itemId))
    var body: some View {
        VStack {
            if let map = offlineMap {
                MapView(map: map)
        .onAppear {
            Task {
                await offlineMapTaskWrapper.generateOfflineMap() { map in
                    self.offlineMap = map
class OfflineMapTaskWrapper: ObservableObject {
    private var offlineMapTask: OfflineMapTask
    private let itemId: String
        let offlinePortalItem = PortalItem(portal: PortalManager.shared.portal!, id: PortalItem.ID(rawValue: itemId)!)
        self.offlineMapTask = OfflineMapTask(portalItem: offlinePortalItem)
    func getDirectoryPath() -> URL {
        let baseDirectory = FileManager.default.urls(for: .documentDirectory, in: .userDomainMask).first!
        return baseDirectory.appendingPathComponent(itemId)
    func generateOfflineMap( completion: @escaping (Map) -> Void) async {
        let parameters = GenerateOfflineMapParameters()
        parameters.includesBasemap = true
        //        parameters.areaOfInterest = extent
        parameters.continuesOnErrors = false
        let temporaryDirectory = getDirectoryPath()
        print("temporaryDirectory: \(temporaryDirectory)")
        print("temporaryDirectory: \(offlineMapTask.portalItem?.id)")
        print("temporaryDirectory: \(PortalManager.shared.portal?.user?.fullName)")
        let generateOfflineMapJob = offlineMapTask.makeGenerateOfflineMapJob(
            parameters: parameters,
            downloadDirectory: temporaryDirectory
        generateOfflineMapJob.start()
        do {
            let output = try await generateOfflineMapJob.output
            let map = output.offlineMap
            //let builder = EnvelopeBuilder(envelope: extent)
//            builder.expand(by: 0.8)
//            map.initialViewpoint = Viewpoint(boundingGeometry: builder.toGeometry())
            DispatchQueue.main.async {
                completion(map)
        } catch {
            print(error)
Nicholas-Furness
Based off the screenshot of the folders, you already have a downloaded map on disk at the location you're trying to download to. When you specify the download location, you should make sure there isn't already something at that location on disk.
There are two things you can do:
  1. If the downloaded map you already have on disk is suitable, you can just re-open that instead of re-downloading it. To re-open without re-downloading, see Step 2 here.
  2. Otherwise, if you need to get a fresh copy of the map, delete the previously downloaded map (folder) and re-download to the same location (or you can download to a different location and keep both copies of the offline maps, but if they're the same map, that's probably not what you want).
Hope that helps.
