ArcGIS URLRequestBuildable.makeURLRequest() - Crash
1601
08-06-2024 12:22 PM
CristhianSanchez
Hello, we have found this crash which occurs when we use the CustomTiledLayer class. We use it to render MBTiles in the map but we haven't found the cause, we are wondering if you have some idea what could be happening, here is an image with part of the stack trace:
rolson_esri
Esri Alum
It looks like we are somehow ending up with a `nil` URL when we didn't expect to. Can you provide some reproducible code please?
CristhianSanchez
Code looks similar to this:
import ArcGIS
class ArcGISMBTilesLayer {
    var customLayer: CustomTiledLayer
    static let defaultSpatialReference = SpatialReference(wkid: WKID(rawValue: 3857) ?? .webMercator)!
    init(mbtilesFilePath: String) {
        let tileInfo = TileInfo(
            dpi: 96,
            format: .png,
            levelsOfDetail: ArcGISMBTilesLayer.defaultLevelsOfDetail(),
            origin: ArcGISMBTilesLayer.defaultOrigin(),
            spatialReference: ArcGISMBTilesLayer.defaultSpatialReference,
            tileHeight: 256,
            tileWidth: 256
        self.customLayer = CustomTiledLayer(tileInfo: tileInfo, fullExtent: ArcGISMBTilesLayer.defaultEnvelope()){(tileKey: TileKey)  in
            let provider = SomeDataMBTilesProvider.getTiles(withPath: mbtilesFilePath)
            let tileY = Int(pow(2.0, Double(tileKey.level))) - tileKey.row - 1
            guard tileY >= 0 else {
                return nil
            let image: UIImage? = ImageFromTile.tile(with: provider, x: UInt(tileKey.column), y: UInt(tileY), zoom: UInt(tileKey.level))
            if let image = image, let data = image.pngData() {
                return data
            else {
                return nil
        self.customLayer.noDataTileBehavior = .blank
    static func defaultEnvelope() -> Envelope {
        return Envelope.init(
            xMin: -2.003750834278E7,
            yMin: -2.003750834278E7,
            xMax: 2.003750834278E7,
            yMax: 2.003750834278E7,
            spatialReference: defaultSpatialReference
    static func defaultLevelsOfDetail() -> [LevelOfDetail] {
        return [
            LevelOfDetail.init(level: 0, resolution: 156543.0339279998, scale: 0.91657527591555E8),
            LevelOfDetail.init(level: 1, resolution: 78271.5169639999, scale: 2.95828763795777E8),
            LevelOfDetail.init(level: 2, resolution: 39135.7584820001, scale: 1.47914381897889E8),
            LevelOfDetail.init(level: 3, resolution: 19567.8792409999, scale: 7.3957190948944E7),
            LevelOfDetail.init(level: 4, resolution: 9783.93962049996, scale: 3.6978595474472E7),
            LevelOfDetail.init(level: 5, resolution: 4891.96981024998, scale: 1.8489297737236E7),
            LevelOfDetail.init(level: 6, resolution: 2445.98490512499, scale: 9244648.868618),
            LevelOfDetail.init(level: 7, resolution: 1222.99245256249, scale: 4622324.434309),
            LevelOfDetail.init(level: 8, resolution: 611.49622628138, scale: 2311162.217155),
            LevelOfDetail.init(level: 9, resolution: 305.748113140558, scale: 1155581.108577),
            LevelOfDetail.init(level: 10, resolution: 152.874056570411, scale: 577790.554289),
            LevelOfDetail.init(level: 11, resolution: 76.4370282850732, scale: 288895.277144),
            LevelOfDetail.init(level: 12, resolution: 38.2185141425366, scale: 144447.638572),
            LevelOfDetail.init(level: 13, resolution: 19.1092570712683, scale: 72223.819286),
            LevelOfDetail.init(level: 14, resolution: 9.55462853563415, scale: 36111.909643),
            LevelOfDetail.init(level: 15, resolution: 4.77731426794937, scale: 18055.954822),
            LevelOfDetail.init(level: 16, resolution: 2.38865713397468, scale: 9027.977411),
            LevelOfDetail.init(level: 17, resolution: 1.19432856685505, scale: 4513.988705),
            LevelOfDetail.init(level: 18, resolution: 0.597164283559817, scale: 2256.994353),
            LevelOfDetail.init(level: 19, resolution: 0.298582141647617, scale: 1128.497176),
            LevelOfDetail.init(level: 20, resolution: 0.149291070823808, scale: 564.248588),
            LevelOfDetail.init(level: 21, resolution: 0.074645535411904, scale: 282.124294),
            LevelOfDetail.init(level: 22, resolution: 0.037322767705952, scale: 141.062147),
            LevelOfDetail.init(level: 23, resolution: 0.018661383985268, scale: 70.531074)
    static func defaultOrigin() -> Point {
        return Point.init(x: -2.003750834278E7, y: 2.003750834278E7, spatialReference: defaultSpatialReference)
//Some class to add layer to map operational layers
class SomeClassToAddMapLayerToMap {
    func setupLayer(filePath: String) {
        let mbTilesLayer = ArcGISMBTilesLayer(mbtilesFilePath: filePath)
        let operationalLayer = mbTilesLayer.customLayer
        addLayers(from: [operationalLayer])
    func addLayers(from layers: [Layer]) {
        viewModel?.selectedMap?.addOperationalLayers(layers)
rolson_esri
Esri Alum
Unfortunately there is missing code for function calls in your code. What would be really helpful is a self-contained reproducible example. Then we can debug and fix the issue.
Nicholas-Furness
Hello @CristhianSanchez. Please could you DM me with some more details? We'd like to reproduce this and see if we can work out a solution. We'll need some data and a self-contained reproducer project.
Thank you!
