ArcGis Map for Swift SDK giving error on adding Feature layer
4550
11
04-05-2024 07:37 AM
ShrutiVaman
I am trying to add Shapefile to the ArcGis map creating a Feature layer. But SDK always gives me an error saying FileNotFoundError(details: "Invalid path or missing shapefile data.")
I am following the code from GitHub https://github.com/Esri/arcgis-maps-sdk-swift-samples
I also tried loading the same shapefiles on ArcGis online it worked.
Can anyone help me fix this problem?
ShrutiVaman
This worked. Thank you so much for the solution. Swift SDK sample code hasn't mentioned I need a UTType extension. So, I was stuck there.
Can you please let me know if there are any problems with the attached shape files? I am not able to create a feature layer and it gives me following error
Ting
by Esri Regular Contributor
I'm not a GIS expert, so I don't know too much about the file structure intrinsics. To my understanding, a shapefile must contain at least 3 files: .shp, .shx, and .dbf. Your zip only has the .shp files.
Maybe ask the question in https://community.esri.com/t5/arcgis-pro-questions/bd-p/arcgis-pro-questions to have someone examine your files. Maybe the person who exported these files missed the require metadata.
