ArcGis Map for Swift SDK giving error on adding Feature layer
4557
11
04-05-2024 07:37 AM
ShrutiVaman
Hello,
I am trying to add Shapefile to the ArcGis map creating a Feature layer. But SDK always gives me an error saying FileNotFoundError(details: "Invalid path or missing shapefile data.")
I am following the code from GitHub https://github.com/Esri/arcgis-maps-sdk-swift-samples
I also tried loading the same shapefiles on ArcGis online it worked.
Can anyone help me fix this problem?
3 Solutions
Ting
by Esri Regular Contributor
Your code logic is correct (despite some minor UI and styling issues) and I'm able to load a shapefile from the bundle with it.
The problem might be how you added the files to the bundle. If you are reading the files from the Documents folder, or using FileImporter, there shouldn't be this problem.
When adding files to an app bundle, please note the difference between Create groups vs Create folder reference, where groups has the gray folder icon in the project navigator, while a folder reference has the blue folder icon.
The key difference between these two is that group is an logical hierarchy, where all the files are stored at the same top level folder of the app bundle, and only grouped logically by the Xcode project file. Whereas a folder reference retains the actually folder structure in the app bundle of the added files.
Because shapefile format is not a single file - it contains various metadata and supporting files, the folder structure needs to be retained. When you add the folder of the shapefile to the project, use the Create folder references radio button.
Please see the code project attached for an idea. Let me know if you have more questions 🙂
Ting
My apologies for a mistake in my previous follow up answer. Instead of passing the folder path in, you'll still need to create the table from a `.shp` file.
Please see the code below
import ArcGIS
import SwiftUI
import UniformTypeIdentifiers
struct ContentView: View {
    @State private var map: Map = {
        let map = Map(basemapStyle: .arcGISTopographic)
        map.initialViewpoint = Viewpoint(
            latitude: 56.6413,
            longitude: -3.8890,
            scale: 6e6
        return map
    @State private var isImporting = false
    @State private var selectedURL: URL?
    var body: some View {
        MapView(map: map)
            .toolbar {
                ToolbarItem(placement: .bottomBar) {
                    Button("Load Files") {
                        isImporting = true
            .task(id: selectedURL) {
                if let selectedURL, selectedURL.startAccessingSecurityScopedResource() {
                    defer {
                        selectedURL.stopAccessingSecurityScopedResource()
                    do {
                        try await loadShapefile(url: selectedURL)
                    } catch {
                        // Handle failure.
                        print("Unable to read file contents")
                        print(error.localizedDescription)
            .fileImporter(
                isPresented: $isImporting,
                allowedContentTypes: [.shp]
            ) { result in
                switch result {
                case .success(let fileURL):
                    selectedURL = fileURL
                case .failure(let error):
                    print("Unable to load file from importer")
    func loadShapefile(url: URL) async throws {
        // Instantiates shapefile feature table with the path to the .shp file.
        let shapefileTable = ShapefileFeatureTable(fileURL: url)
        try await shapefileTable.load()
        // Creates a feature layer for the shapefile feature table.
        let shapefileLayer = FeatureLayer(featureTable: shapefileTable)
        // Adds the layer to the map.
        map.addOperationalLayer(shapefileLayer)
// Data for testing can be downloaded from https://www.arcgis.com/home/item.html?id=15a7cbd3af1e47cfa5d2c6b93dc44fc2
private extension UTType {
    /// A type that represents a shapefile.
    static let shp = UTType(filenameExtension: "shp")!
Ting
I'm not a GIS expert, so I don't know too much about the file structure intrinsics. To my understanding, a shapefile must contain at least 3 files: .shp, .shx, and .dbf. Your zip only has the .shp files.
Maybe ask the question in https://community.esri.com/t5/arcgis-pro-questions/bd-p/arcgis-pro-questions to have someone examine your files. Maybe the person who exported these files missed the require metadata.
Ting
Can you share your code or a reproducible project to load the shapefile? From the error message it is hard to tell what the exactly problem is - either the shapefile folder is missing some metadata files, or the path you passed in is not recognized. Thanks.
ShrutiVaman
Here is my code
    @State private var presentError : Bool = false
    @State private var error: Error?
             latitude: 34.723638,
             longitude: -92.500932,
             scale: 72_000
         return map
        MapView(map: map)
            .toolbar(content: {
                ToolbarItem(placement: .bottomBar,content: {
                    Text("Load Shapefile")
                        .task {
                            do{
                                try await LoadShapefile()
                            }catch{
                                print(error)
                                self.error = error
            .onAppear{
                ArcGISEnvironment.authenticationManager.arcGISAuthenticationChallengeHandler = ChallengeHandler()
            .onDisappear{
                ArcGISEnvironment.authenticationManager.arcGISAuthenticationChallengeHandler = nil
            .alert(isPresented: $presentError){
                Alert(title: Text("Something went wrong"), message: Text(error!.localizedDescription))
    func LoadShapefile() async throws{
        print("shapefile ",URL.shapefilePath.absoluteString)
        let shapefileTable = ShapefileFeatureTable(fileURL: .shapefilePath)
        try await shapefileTable.load() // Throwing error
    private struct ChallengeHandler: ArcGISAuthenticationChallengeHandler {
        func handleArcGISAuthenticationChallenge(
            _ challenge: ArcGISAuthenticationChallenge
        ) async throws -> ArcGISAuthenticationChallenge.Disposition {
            // NOTE: Never hardcode login information in a production application.
            // This is done solely for the sake of the sample.
            return .continueWithCredential(
                try await TokenCredential.credential(for: challenge, username: "myusername", password: "my password")
private extension URL{
    static var shapefilePath : URL { Bundle.main.url(forResource: "test", withExtension: "shp")! }
I have also added files under the Copy Bundle Resource in Build Phase.
I tried reading another text file using Bundle. It worked fine. Just the shape file is giving an error.
Ting
ShrutiVaman
Thank you so much. It worked. My main use of this app is to allow users to download the Shapefile and read it. Do I have to ask the user to download the folder containing .shp, .prj, .dbf, .shx files?
Ting
Yes. See this doc for details. It would be good to be a zip file with an enclosing folder that contains all the components.
ShrutiVaman
I tried this and it didn't work. Always get an error saying
ArcGISError(code: 10012, description: "Unknown error.", details: "boost::filesystem::status: Operation not permitted [system:1])
Ting
Can you share the specifics?
Do you mean you tried to use the path to a zip file to create a shapefile? That won't work. It still needs to be extracted to a folder.
If the shapefile folder is coming from app's Documents folder or user's file importer, to get the folder structure to create a shapefile, the best would be acquiring the enclosing folder's path.
ShrutiVaman
I am trying to import the shapefile from the file importer and using the URL to load shape file. Here is the code.
 .fileImporter(
                allowedContentTypes: [.folder,.zip,.item],
                allowsMultipleSelection: false,
                onCompletion: { result in
                    switch result{
                    case .success(let file):
                        isChangingView = true
                        print("file ",file)
                        do {
                            guard let selectedFile: URL = try result.get().first else { return }
                            let gotAccess = selectedFile.startAccessingSecurityScopedResource()
                            if !gotAccess { return }
                            self.selectedFile = selectedFile
                            LoadShapefile(self.selectedFile)
                            selectedFile.stopAccessingSecurityScopedResource()
                        }catch {
                            // Handle failure.
                        print("error ",error.localizedDescription)
func LoadShapefile(shapefilePath:URL) async throws{
        print("shapefile ",shapefilePath?.absoluteString)
        let shapefileTable = ShapefileFeatureTable(fileURL: self.shapefilePath!)
This is giving me the error  ArcGISError(code: 10012, description: "Unknown error.", details: "boost::filesystem::status: Operation not permitted [system:1])
Ting
import ArcGIS
import SwiftUI
            latitude: 56.6413,
            longitude: -3.8890,
            scale: 6e6
        return map
        MapView(map: map)
            .toolbar {
                        isImporting = true
                    defer {
                    do {
                    } catch {
                        // Handle failure.
            .fileImporter(
            ) { result in
                switch result {
