Water utility network reporting - profiling tool
1813
11-08-2013 12:28 AM
pabloberlanga_jimenez
Hello!
I'm trying to run the Profiling tool included in the water utility network reporting toolbar.
I'm using the example data included in the download.
It doesn't work. I get this error when I try to select the first point (Sewer Manholes) :
[ATTACH=CONFIG]28951[/ATTACH]
"error object reference not set to an instance of an object"
I didn't edit the config file becouse I'm using the example data.
Thank you in advance!!!
