using https map service
1039
11-25-2013 10:03 AM
PeterHoffman
Is there anything special to change when using map services that start with https?
I have changed this in the proxy.config file.
PeterHoffman
Working with ESRI support I found that the production system had different projection data, fixed and it works OK now.
