<--snip--> <ProxyConfig mustMatch="false"> <serverUrls> <serverUrl url="http://ourserver/arcgis/rest/services/" matchAll="true" token="SECRETTOKEN"></serverUrl> </serverUrls> </ProxyConfig>
http://ourserver/arcgis/rest/services/TaxParcelQuery/MapServer/0?token=SECRETTOKEN
function CreateDynamicServiceLayer(layerURL, layerIndex, layerId, isVisible, displayName) { var imageParams = new esri.layers.ImageParameters(); var lastindex = layerURL.lastIndexOf('/'); imageParams.layerIds = [layerIndex]; imageParams.layerOption = esri.layers.ImageParameters.LAYER_OPTION_SHOW; var dynamicLayer = layerURL.substring(0, lastindex); var baseLayerURL = layerURL.substring(0,layerURL.lastIndexOf('?')); //kb - is without token. var token = layerURL.substring(layerURL.lastIndexOf('?')+1, layerURL.length); //kb - is "token=abcxyz" token = token.substring(token.lastIndexOf('=')+1,token.length); dynamicLayer = dynamicLayer + "?token="+token; var dynamicMapService = new esri.layers.ArcGISDynamicMapServiceLayer(dynamicLayer, { id: layerId, imageParameters: imageParams, visible: isVisible }); var querySeparator = layerURL.lastIndexOf('?') ? '&' : '?'; //kb dojo.io.script.get({ url: layerURL + querySeparator + 'f=json', //kb updated preventCache: true, callbackParamName: "callback", timeout: 10000, load: function (data) { layersCounter++; if (layersCounter == layers.length) { HideProgressIndicator(); } var table = document.createElement("table"); var tbody = document.createElement("tbody"); table.appendChild(tbody); var tr = document.createElement("tr"); tbody.appendChild(tr); var td = document.createElement("td"); var checkbox = CreateCheckBox(layerId, layerIndex, false); checkbox.onclick = function () { if (this.getAttribute("state") == "check") { this.src = "images/unchecked.png"; this.setAttribute("state", "uncheck"); dynamicMapService.hide(); map.infoWindow.hide(); } else { this.src = "images/checked.png"; this.setAttribute("state", "check"); ShowProgressIndicator(); dynamicMapService.show(); map.infoWindow.hide(); selectedGraphic = null; map.getLayer(tempLayerId).clear(); map.getLayer(tempParcelLayerId).clear(); } HideProgressIndicator(); }; td.appendChild(checkbox); tr.appendChild(td); td = document.createElement("td"); var img = document.createElement("img"); img.src = baseLayerURL + '/images/' + data.drawingInfo.renderer.symbol.url; if (isMobileDevice) { img.style.width = "44px"; img.style.height = "44px"; } else { img.style.width = "20px"; img.style.height = "20px"; } td.appendChild(img); tr.appendChild(td); td = document.createElement("td"); td.appendChild(document.createTextNode(displayName)); tr.appendChild(td); dojo.byId('divLayers').appendChild(table); }, error: function (error) { layersCounter++; if (layersCounter == layers.length) { HideProgressIndicator(); } } }); return dynamicMapService; }
// Get token, if applicable, and append to the request string token = "SUPERSECRETTOKEN"; //getTokenFromConfigFile(uri); <-- this method didn't work so I hard coded it here for now. if (!String.IsNullOrEmpty(token)) { if (uri.Contains("?")) uri += "&token=" + token; else uri += "?token=" + token; } System.Net.HttpWebRequest req = (System.Net.HttpWebRequest)System.Net.HttpWebRequest.Create(uri); req.Referer="http://gisweb/TaxParcelViewerCTUIR/"; //kb:::added to make the token work!
