Regenerate Parcels
916
01-16-2013 04:50 AM
JAKERODEL
Is it appropriate to run the Regenerate tool on your entire parcel Fabric?  Would that produce any unexpected consequences?
TiffanyPuett
Ran it many times...haven't encountered anything yet.  What version of Desktop are you running? SP?  You don't really see the need as much in 10.1 to use that tool.
Also, what makes you think you need it? Are you experiencing some odd behavior?  It could be that you need another tool. I'd be happy to recommend something.
JAKERODEL
Well when I run a check fabric I get a bunch of errors for missing radial lines and some points that do not belong to a parcel or control point.  Just seemed like that might clean some of that up.  I wasn't sure if I would get other unexpected results though.  Thanks!
