Random Rounding Error??
3658
04-18-2014 11:39 AM
AnthonyGalante
I have a field that is double with no defined precision or scale and populated with real numbers.
I create a new field, same format, and use field calc to subtract each number by .01
I create another field, same format, use field calc to subtract new number from original.
I get results, seemingly randomly, that range from .01 to .009xx.
WHY?
ver 10.1 build 3143
ChrisBuscaglia
WHY?
ver 10.1 build 3143
Hello,
You may want to post this question in the GeoDatabase forum:  http://forums.arcgis.com/forums/32-Geodatabase-amp-ArcSDE
Chris - Solutions
