Join link on a curve
3559
04-24-2014 06:42 PM
JeffWard
Honored Contributor
Hi Everyone,
I am trying to join a parcel to an existing parcel where one of the points of the joining parcel is along a curve of the existing parcel.  When I try to add a join link from the point to the line, I get the "Create join link failed: To create a join link, select 2 points or select a point and a line (no curve)." error message.  What do I need to do in this case?  Leave that point unjoined and create links for all of the other points?
Thanks in advance for any replies.
Jeff Ward
Summit County, Utah
JeffWard
Honored Contributor
Thanks for the help Frank, so I will join at the radius point and the endpoint of the arc that both parcels share.
Jeff Ward
Summit County, Utah
