Problem with Attribute Assistant
5291
08-28-2013 06:37 AM
by Anonymous User
Not applicable
Original User: JayCarp
I have a problem with Attribute Assistant.  In short, there are instances where the change rules in my Generate ID method are not being followed.  I created a point and polygon feature class to test this behavior.  Hopefully someone can let me know if I am doing something incorrectly or it is a bug.
My Action:
1. Create point and poly FC and setup each with a FID text field and a 'name' attribute field.
2. Setup each feature class so the FID fields auto-generate ID using GenerateID table and dynamic value table.  Dynamic Value table 'On Create' is set to 'True' while the remainder (On Change Geometry and Attribute, Manual Only) are set to 'False'.
3. With these point and polygon FC in Arcmap (10.1 sp1) start editing and create a point.  The point FID field is properly generated with the first # in the sequence.
4.  Then if I edit the 'name' attribute the FID doesn't change as expected.
5.  Next I created a polygon and again noted that the FID was properly generated.
6.  This step is the trigger to the undesired behavior, I select the polygon or Point either one and click the "Triggers a create event on each selected feature' button in the Attribute Assistant toolbar at which point the FID is regenerated with a new ID.
7.  Now since I have clicked that 'Triggers a create event on each selected feature' button, anytime I change the 'name' attribute field it regenerates a new FID.  This happens even if you turn editing off and back on again and it happens on either of the feature classes regardless if it was the feature class you triggered the create on event through the toolbar.  It also happens if you turn the Attribute Assistant off and then back on. The only way I have found to clear this out is to shut down Arcmap and reopen the mxd.
Summary, Attribute assistant is ignoring the change rules I have setup once I manually trigger a create event from the toolbar.  Modifying an attribute field triggers an On_Create from that point forward.  When you manually click the 'trigger a create event on each selected feature' button a dialog pops and lets you know that it did something.  There was no indication that the FID was being changed when I was editing the 'name' attribute.
I am on Arcmap 10.1 and Attribute Assistant 10.1.1.1
I have not tested this any further and with different methods.  I think the attribute assistant is a great tool in concept and will use it regularly so long as I can count on it to work properly.  FID's changing without warning is not a good thing in my mind and makes me wonder what else changes that I might not notice.
Jay
MikeMillerGIS
Esri Frequent Contributor
Jay,
   We have identified this as a bug and have resolved it in the 10.2 release.  If you require a 10.1 version, please contact us at [email protected].
by Anonymous User
Not applicable
Original User: lind5149
We are working on Releasing this now.
It should be coming in the first quarter of 2014. I'll post again once it is released.
-Lindsay
LindsayThomas
We have updated all of our Editing Maps at 10.1 with a new build of the Local Government Add-ins (including Attribute Assistant)
You can get the latest Attribute Assistant add-in from any of the downloads below:
Please note: Current 10.1 users should backup the Loaded.config file before updating to the 10.1.1 QIP release.  This update includes significant changes to the Add-ins which now share the same configuration file schema as the 10.2 Add-ins.  Additional information on the new configuration file can be found in the ArcGIS for Local Government 10.2 Help.
New 10.1.1 users are not be affected by changes in the Loaded.config file and can install the latest release.
Pre-Fire Planning 10.1: http://www.arcgis.com/home/item.html?id=aa2071ab53964216bfca7bd9eed057f2
Campus Editing 10.1: http://www.arcgis.com/home/item.html?id=4eb4cb3f42fd4af699a0d76cf91834b0
Flood Planning 10.1: http://www.arcgis.com/home/item.html?id=bebbfc44c1724d9da0d41039cf4706df
Special Events Planning 10.1: http://www.arcgis.com/home/item.html?id=d80b88a7acf841249bdacc259a2c7c94
Water Utility Editing 10.1: http://www.arcgis.com/home/item.html?id=385978c927124489b4dc6110eded38df
Water Utility Capital Improvement Planning: http://www.arcgis.com/home/item.html?id=18ef915ca1794ea7b0f424cb8f6687bf
Address Data Management 10.1: http://www.arcgis.com/home/item.html?id=915796ef17124d09a25130c223835474
-Lindsay
