Hi Mark,
I followed your steps. When I stepped through the debugger:
layerID: Array[1] 0:0, length: 1
searchfields: Array [1] 0: FacilitySitePoint.NAME
Searchtext: Ypres
When I go to the services directory and add these to the Find task, it says "No Results Found"
I used an MSD that was published for all of these tasks.
I tried something different: I published the MXD directly. When I do the find task in the services directory, using the values above, I actually get the expected result. Problem is, when I use the map service published from the MXD, the application doesn't work. When I search on the name of a park, or an activity, I get the message: 'feature.attributes[...]' is null or not an object
Could the issue be the difference between an MSD and an MXD? If that's the case, how can I get the MXD to work in my application since it is the only way to get the results?
Thanks again for all of your help,
Allison
