How did you fix this problem?
I am having difficulty getting this application to work properly without error & have configured js, published services & configured application exactly like is says to do...
Hi Alexander,
I don't know what exactly is causing your problem. But when I had the attachment issue, I just simply enabled attachment for the Parks feature class. To do this, you can right click the feature class in ArcCatalog, go to manage, and select Create Attachments.
Hope this helps!
Thank you, yes I have figured that issue out.
Any idea as to why this is showing up? Im scanning my js config file now to look for any typos but i do not believe there are any...
"required configuration key values are either null or not exactly matching with layer attributes this message may appear multiple times"
