Parcel layer fabric not compatible with Parcel Workflows - 10.2.1
3054
05-22-2014 07:12 AM
Zeke
Honored Contributor
When I try to use Parcel workflows on a parcel fabric (either one I created or the sample supplied with the Tax Editing Map), I get an error stating that "This Parcel Fabric is not compatible with Parcel Workflows'. Why is this? I'm running Arcgis 10.2.1 Advanced, build 10.2.1.3497 on Windows 7 Pro. The LGIM is enabled on the parcel fabric.
I first thought that maybe workflows are only available at 10.2.2, but don't find this documented anywhere. Any clues? Thanks.
edit - fixed the problem by removing the parcel fabric and adding it back in. Leaving the post up in case anyone else runs into this.
AmirBar-Maor
Thanks for sharing.
To clarify again:
After you enable the information model, drag and drop the parcel fabric from the Catalog window to an empty map.
Amir
