Need Help getting started with LGIM
4821
10
06-04-2013 12:57 PM
DenisCalarco
So, after searching through the forums here, I have reached a point where I still have no idea what is going on.
We are basically starting fresh in my municipality.  I would like to use the Local Govt. Infrastructure editing tools, but I cannot for the life of me figure out how to get started.
The download came with alot of information already, for the place in IL.
What I need to find out is:
1. How can I easily change everything to my local coordinate system instead of IL State Plane?
2. How can I remove all of the existing features, like pipes and manholes and stuff, so that I can replace it with my own?
3. Can I use this with my ArcPad installation to collect new info in the field?
I tried to create a new map, and insert the stuff from the gdb in the download, but none of the symbols or linetypes carry over.
Sorry , Im sure this has been discussed, but Im overwhelmed by all of the information available.
Thank you so much!
D
ScottOppmann
One other note, don't hesitate contacting Esri Support Services if you are still having trouble configuring the information model and getting the editing map set up.  They can help you with the specific issues you may still be having.
Scott
