Modified Nearest Feature
1493
11-19-2013 01:27 PM
JeffMiller
Hello all,
     I have a question regarding the nearest feature function in the attribute assistant, and I was hoping someone far smarter than I could shed some light on this.
     I have an odor control feature class that contains a field called featuretype, which is populated by a domain containing SINJECT and AIRJUMP options.  Utilizing the nearest feature rule, I would like to populate the SFACILITYID field in this table with the facility ID from the nearest Facility whenever a new odor control line is created.  The catch, however, is that I only want this to occur when the featuretype is set to SINJECT, as the AIRJUMP devices are not truly associated with a facility.  I'm not sure if there is a way to modify this rule, or if there is another rule that I'm missing that may do the job.
     Any help would be much appreciated!
Cheers!
