Local Government Model able to be used for multi-modal routing?
453
11-08-2012 08:32 AM
BryanKaraffa
I am coordinating with a campus that is looking to migrate our campus data into a data model that supports routing.  We've been introduced to the Local Government Information model at the ESRI user conference and are starting to do our research and find the best solution for our application.
Our first concern is that the Local Government Model does not have the appropriate attributes to support multi-modal routing (Oneway paths, Twoway paths, Turn Restrictions, Elevators and Indoor stairways for ADA routing, etc..).  I find it hard to believe that such a robust data model doesn't have the functionality to support routing and was hoping on getting some insight into this.
Any resources or help regarding this would be much appreciated!!
Thanks!
ScottOppmann
Bryan
We have not developed a set of maps and apps for routing on campuses and in buildings yet.  The foundation is there for your campus data, you'll just need to add the routes.  We've developed several prototypes internally, but probably won't release this till late 2013 because of other priorities.
Scott
