Land Use Public Notification-WebMap not Buffering all parts of a Multi-part Parcel
2722
12-26-2013 06:21 AM
JBald
I am in need of a solution or info on where I can turn to find the solution.  I do not know if this is a bug or if there is a configurable fix for this problem.
I configured the Land Use Parcel Notification web service for our town.  We set it up so that it is only available inside our network.
Everything is working great except when a multi-part polygon is selected for buffering.  (ex. one parcel divided by a road or stream )
Then I select the parcel, the map shows all pieces of the parcel are selected (highlighted).  However when I select the buffer distance, and check "labels" and click "download", the buffer is created around only one piece of the multi-part polygon, so many abutters are not selected and are missing from the labels and the .csv file.
Why is the application not using all pieces of the selected multi-part polygon before the buffer is applied?
Where do I need to look to change this?
I tried looking in Locater.js and the utility.js files for a module that defines how the buffer is applied, but I was unsuccessful.  I do not know if I am off course or where else should I be looking.
I have searched threads, forums, scripts, everywhere for a answer to this.  I am surprised that I cannot find a discussion anywhere about it.
I am using ArcGIS Server Version: 10.0  and the Land Use Public Notification application.
Thank you so much,
Judy
