Land Use Public Notification - selection changes after export.
4053
10-08-2015 09:48 AM
JeffWard
Honored Contributor
Hello again.
In my quest to implement the Land Use Public Notification app I am seeing some weird behavior with the graphics that highlight the selected property.
I am able to select a property and click on the envelope to begin exporting the mailing labels.  After I fill out the form and click "Download" the red buffer graphic comes up but the original selected parcel jumps to another parcel that the buffer intersects.  See pic -
The original selection was the parcel in the middle of the buffer.  It jumped to the one on the northeast corner after "Download" was clicked.
Is this a bug?  Can I fix it? Jake Skinner
Thanks for any help.
Jeff
Jeff Ward
Summit County, Utah
JakeSkinner
Esri Esteemed Contributor
Hi Jeff,
What is the projection of the map service you are using?
JeffWard
Honored Contributor
I have an imagery cache and the taxparcelquery service.  Both are in Web Mercator.
Jeff Ward
Summit County, Utah
JeffWard
Honored Contributor
Any thoughts Jake Skinner​?
Jeff Ward
Summit County, Utah
JakeSkinner
If the app is external, would you be able to share the link?
JeffWard
Honored Contributor
It is not external, but I could send you the app folder if that would help.
Jeff Ward
Summit County, Utah
