Intersect tool; automatically changes the field names.
10465
21
09-23-2015 08:55 AM
ToyaShannon
Why does the attribute name fields change after performing an intersect?
JoeBorgione
Can you provide an example?  What version ArcGIS are you using?
That should just about do it....
ToyaShannon
I am using 10.3.
Attribute table BEFORE intersect:
Attribute table AFTER intersect:
JoeBorgione
I'm using 10.0; it adds a few fields but leaves the originals intact.  Sorry, can't comment on 10.3; you may have discovered an undocumented feature, aka bug....
ToyaShannon
It's weird. This particular intersection has changed the name of the original fields altogether. Thanks for your time.
MitchHolley1
Try unslecting 'ALL' from the 'JoinAttributes' field in the 'Interset' tool window. Instead, select 'ONLY_FID'.Capture.PNG
Are you sure it is replacing the fields and not just inserting and pushing the original fields to the right?
Let me know what happens.
ToyaShannon
Thanks Mitch Muskchamp, but selecting 'ONLY FID', deleted all the data in the attribute table.
MitchHolley1
Could you zip the two files you're attempting to run this 'Intersect' process on and post them here?
ToyaShannon
Oh how I wish I could; unfortunately this data has privileged information.
MitchHolley1
Again, are you sure the new fields aren't just added fields?  And they're just pushing over the older fields to the right?
