Implementing Park Finder through ArcGIS Server 10.1: issues with search by name
3246
06-11-2014 11:09 AM
YichiLiu1
Hi all,
I have another question about Park and Recreation Finder:(. I have implemented Park and Recreation Finder and enables route service. When I did "Search" by "Name", the browser was able to pull out the park info, however, I didn't see a dark circle indicating the location of selected park and the map didn't pan to the selected park. Same issue happened to search by activities as well. This is how it suppose to look like [ATTACH=CONFIG]34508[/ATTACH].
This did not appear to be a problem when I was using 10.2 in our test server. But the server we are actually using now has 10.1 and currently we are not planning to upgrade it. So I am using ArcGIS Server 10.1 and the 10.2 template for park finder.
Any ideas or suggestions about solving this problem?
Thanks in advance!
MalcolmEchaluce
Hi all,
Thanks in advance!
Were you able to find a solution to this issue?  I am having the same problem with mine.  Thanks!
YichiLiu1
No, I haven't found anything yet. I called ESRI's technical support and they suggested me to upgrade my server to 10.2. However, I have upgraded my server and the problem still exists. 😞
