Error importing sample LocalGovernment.xml
1979
05-15-2018 08:39 AM
deleted-user-VufWHY1x18C_
Hi! I have been using ArcMap for quite some time now, but am very new to the Local Government Information Model. I am currently using ArcGIS Desktop 10.5 on a new Windows 10 x64 PC. I was hoping to use Address Data Management model for maintaining our city roads and addresses. However, I cannot even get the Local Government schema imported into ArcCatalog. I have installed the X-Ray for ArcCatalog Add-In and verified that it is enabled. I then created a new file geodatabase in ArcCatalog, however when I try to open the LocalGovernment.xml workspace document I receive this error...
This is what is listed under Details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'office, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' or one of its dependencies. The system cannot find the file specified.
File name: 'office, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c'
at XRayArcCatalog.XRayDockableWindow.copyToXlsx(String xlsPath, String xlsxPath)
at XRayArcCatalog.XRayDockableWindow.copyAllToXlsx() in c:\Users\mike6491\ag\x-ray-for-arc-addins\XRayArcCatalog\xslt.cs:line 239
at XRayArcCatalog.XRayDockableWindow.openXML() in c:\Users\mike6491\ag\x-ray-for-arc-addins\XRayArcCatalog\xslt.cs:line 225
at XRayArcCatalog.XRayDockableWindow.btnOpenXML_Click(Object sender, EventArgs e) in c:\Users\mike6491\ag\x-ray-for-arc-addins\XRayArcCatalog\XRayDockableWindow.cs:line 217
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3062.0 built by: NET472REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
ESRI.DADF.Core
Assembly Version: 10.5.0.0
Win32 Version: 10.5.0.6491
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/ESRI.DADF.Core.DLL
ESRI.ArcGIS.Desktop.AddIns.Factory
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/ESRI.ArcGIS.Desktop.AddIns.Factory.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/ESRI.ArcGIS.Desktop.AddIns.DLL
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
XRayArcCatalog
Assembly Version: 10.2.0.3
Win32 Version: 10.2.0.3
CodeBase: file:///C:/Users/cdavis.ANDERSON/AppData/Local/ESRI/Desktop10.5/AssemblyCache/%7BAB7D758E-ACB2-4583-8E74-CC9234ADA719%7D/XRayArcCatalog.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
ESRI.ArcGIS.Catalog
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Catalog/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Catalog.dll
ESRI.ArcGIS.CatalogUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.CatalogUI/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.CatalogUI.dll
ESRI.ArcGIS.System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.System/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.System.dll
ESRI.ArcGIS.Framework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Framework/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Framework.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Security
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
GpMetadataFunctions
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/GpMetadataFunctions.DLL
ESRI.ArcGIS.Geoprocessing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Geoprocessing/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Geoprocessing.dll
ESRI.ArcGIS.Geodatabase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Geodatabase/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Geodatabase.dll
ESRI.ArcGIS.SearchUI
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/ESRI.ArcGIS.SearchUI.DLL
ESRI.ArcGIS.SearchControl
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/ESRI.ArcGIS.SearchControl.DLL
ESRI.ArcGIS.SearchCore
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/ESRI.ArcGIS.SearchCore.DLL
ESRI.ArcGIS.Carto
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Carto/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Carto.dll
ESRI.ArcGIS.Search
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Search/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Search.dll
ESRI.ArcGIS.SystemUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.SystemUI/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.SystemUI.dll
ESRI.ArcGIS.Version
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Version/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Version.dll
ESRI.ArcGIS.ArcMapUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.ArcMapUI/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.ArcMapUI.dll
System.Data.SqlXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
System.Xml.Xsl.CompiledQuery.1
Assembly Version: 0.0.0.0
ESRI.ArcGIS.Geometry
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Geometry/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Geometry.dll
Lucene.Net
Assembly Version: 2.9.2.1
Win32 Version: 2.9.2.1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Lucene.Net/2.9.2.1__402f1553d5c332e7/Lucene.Net.dll
Snowball.Net
Assembly Version: 2.0.0.1
Win32 Version: 2.0.0.1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Snowball.Net/2.0.0.1__402f1553d5c332e7/Snowball.Net.dll
ESRI.ArcGIS.ArcGlobe
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.ArcGlobe/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.ArcGlobe.dll
ESRI.ArcGIS.ArcScene
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.ArcScene/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.ArcScene.dll
ESRI.ArcGIS.Display
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Display/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Display.dll
System.Web
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
ESRI.ArcGIS.GlobeCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.GlobeCore/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.GlobeCore.dll
ESRI.ArcGIS.3DAnalyst
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.3DAnalyst/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.3DAnalyst.dll
ESRI.ArcGIS.GeoprocessingUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.GeoprocessingUI/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.GeoprocessingUI.dll
ESRI.ArcGIS.Client.Local.Private
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.3152
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.5/bin/ESRI.ArcGIS.Client.Local.Private.DLL
System.ServiceModel.Web
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
SMDiagnostics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Internals
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
ESRI.ArcGIS.GeoDatabaseDistributed
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.GeoDatabaseDistributed/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.GeoDatabaseDistributed.dll
ESRI.ArcGIS.DataSourcesGDB
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.DataSourcesGDB/v4.0_10.5.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.DataSourcesGDB.dll
Microsoft.Office.Interop.Excel
Assembly Version: 15.0.0.0
Win32 Version: 15.0.4569.1506
CodeBase: file:///C:/Users/cdavis.ANDERSON/AppData/Local/ESRI/Desktop10.5/AssemblyCache/%7BAB7D758E-ACB2-4583-8E74-CC9234ADA719%7D/Microsoft.Office.Interop.Excel.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I tried removing all mention of X-Ray and Local Government from my PC and then downloading Add-Ins and files again and am still receiving the same error messages. I am by no means a programmer and have absolutely no clue what any of that means. Has anyone else received this error and know how to fix it? I've tried searching for a fix, but all the ways I have seen to enable the JIT Debugging involve Microsoft Visual Studio, which I do not have on my computer. I do have .NET Framework.
Thank you!
Cassie
AllisonMuise1
Hi Cassie,
What version of Microsoft Office do you have installed? The initial error message looks like it's having a hard time finding Microsoft Excel.
Allison
Hi Allison,
I am using Microsoft Excel 2016 MSO 32-bit. It’s part of the Microsoft Office 365 ProPlus subscription.
Thank you!!
Cassie
AllisonMuise1
hmm...I believe that should work. Your best bet might be to call Esri Support Services for help. They can help troubleshoot this and get to the bottom of what's not working.
