Election polling places publishing problem
3167
6
08-01-2013 07:26 AM
PeterHoffman
I am trying to publish the ParcelPublicAccess map service and it will not finish - not responding message. I have successfully published the other 2 map service without a problem.I am running 10.1 sp1.
Also I could not find the mixed90cachesettings.xml file.
I tried with and without caching.
RafaelFernandez1
Hi Peter,
A question for you: could you see the demo working fine in your server?
I think it is the first stage, later you can change a service, later another. I mean, step by step.
Rafael
PeterHoffman
The demo application on ESRI's website works fine.
Does anyone have a version of the config.js that shows the correct url's that are on the ESRI website so I can test my application that way?
I do not get the splash screen in my version.
PeterHoffman
i cannot access that file.
RafaelFernandez1
Try it from this thread:
http://forums.arcgis.com/threads/89533-Seting-the-newest-Election-Polling-Places
Rafael
PeterHoffman
Ok, trying that config.js getting same lack of response.
Using firefox I get this info from Firebug:
TypeError: responseObject.LocatorFields is undefined
http://gistestdev/electionpollingplace/default.htm
Line 306
PeterHoffman
Got everything to work.
1. Typos in config.js - my fault.
2. I used the 10.1 version and put in the ESRI's url's and got the site to work.
3. I cached my ParcelPublicAccess service and it then worked using my 3 map services.
4. My coworker found the location of the cache.xml file and we used that.
