DefaultExtent in ParkandRec Finder not working
1301
06-26-2013 07:18 AM
EvanO_Keefe
I'm running into an issue with the default extent in the Parks and Recreation Finder app. Obviously it works fine with the Naperville extent, but when I change it to my location it does some funky things. Normally it zooms in to the closest extent. I can zoom out and it's in the semi-correct location. Other times (with the exact same coordinates) it zooms to the Mediterranean Sea. If I put the Naperville coordinates back in it works fine. Has anyone else had issues with it? I'm using the Rec Finder for 10.1. Thanks!
//Initial extent of map. To separate values use �??,�?� symbol.
 'DefaultExtent':"-12196644.48, 4487055.57, -11899851.73,  4284107.31",
