Create Street Index Report error
3934
11-04-2014 09:45 AM
EvaShoemaker-Maffei
I'm running the Create Street Index Report tool from the FireRunBook 10.1 application.  I keep getting this error:
Executing: CreateStreetIndexReport V:\GISCoordinator\master_data\StevensCountyBasemapData.gdb\Transportation\RoadsAll STREET V:\GISCoordinator\master_data\StevensCountyBasemapData.gdb\AdministrativeBoundaries\StCoPages PAGE PORTRAIT V:\GISCoordinator\Addressing\Intrado\RdList14.pdf
Start Time: Tue Nov 04 09:38:56 2014
Running script CreateStreetIndexReport...
--Dissolving road centerlines...
  File "C:\Downloads\ESRI\FireRunBookfor10.1\Application\StreetIndexReport.py", line 257, in <module>
    main(*argv)
  File "C:\Downloads\ESRI\FireRunBookfor10.1\Application\StreetIndexReport.py", line 235, in main
    dissolve_result = arcpy.management.Dissolve(road_centerlines,  os.path.join(scratch_workspace, 'centerlines_dissolve'), full_name)
  File "C:\Python27\ArcGIS10.1\Lib\ntpath.py", line 96, in join
    assert len(path) > 0
TypeError: object of type 'NoneType' has no len()
Failed to execute (CreateStreetIndexReport).
Failed at Tue Nov 04 09:38:58 2014 (Elapsed Time: 2.00 seconds)
Can someone help me with this?  Thanks!
Tags (1)
EvaShoemaker-Maffei
I did get rid of the streets that had 0.  But what I didn't have open was ArcMap.  I was just running the tool from ArcCatalog.  So I added my streets layer and Index layer to a mxd and it worked from there.  Lesson learned!  Thanks for your help - eva
JoeBorgione
Just a shot in the dark:  check your streets for those with 0 or <null> length or empty geometry
That should just about do it....
EvaShoemaker-Maffei
