ArcMap closes with stopping working error when Attribute Assistant is installed
3139
11-06-2014 09:56 AM
SandraLuken
ArcGIS Desktop 10.1 SP1
Attribute Assistant v1.0
Every time ArcMap is closed when AA is installed, it will produce an error (see attached). If AA is not installed there is no error message The error occurs regardless if the users is prompted to save a log file or if the Add-In is turned on or off.
Attribute Assistant and ArcMap functionality seems to be unaffected by this error message on close, except it does solicit a feeling of uneasiness that the application is unstable or has not closed properly.
