Create Remainder creating Line Errors
2596
03-13-2013 08:45 AM
ChrisCorwin
Want to see if anyone else is seeing this issue. It seems that when I use the Create Remainder tool, I get Line Errors. Lines that are not associated with a parcel. The lines and the parcels are in their associated tables but when I run the Check Fabric tools, it gives me the error " Line does not belong to an parcel in the database".  But if I identify the line segment in the table, it has a parcelID associated with it. And I look in the Parcels table and there is a record/objectID for that parcel.
Just thought I would throw it out here before I submit a support request.
Thanks.
TiffanyPuett
Chris,
What version are you on? Does the associated parcel have a value of 1 in the historic field or a system end date?
I have seen some similar problems related to historic parcels. The only workaround that I have found is saving edits and restarting ArcMap. This will occasionally "fix" features that should be pushed to history.
ChrisCorwin
We are on 10.1 SP1 with the Parcel Performance Editing Patch.
I have not noticed those two attributes. I have only been editing current parcels. But I will look while I am testing and see what I find. I sent in a support request to ESRI and they are seeing if they can replicate the issue.
