Citizen Problem Reporter - Schema
2559
09-26-2016 12:30 PM
RickeyFight
I am trying to find the schema for the Citizen problem reporter. I have found the service online but I want to host the data myself.
Here is a link to esri hosted layers.
http://www.arcgis.com/home/item.html?id=d9744b384f854cb39b8b4ffbc68d4502
Can someone point me in the right direction
JakeSkinner
Esri Esteemed Contributor
Hi Rickey,
At the bottom right of the page you provided you will see the URL to the feature service with an option to copy it.  Copy the URL and then go to your Organization > My Content >  Create > Feature Layer > From URL > paste in the URL.
JakeSkinner
Hi Rickey,
RickeyFight
After that you can download to a file geodatabase.
Thank you for your help.
JakeSkinner
Yes, you will have the ability to Export the feature service to a File Geodatabase.  This will be exported to your 'My Content' as a zipped File Geodatabase.  You can then download this file to your local desktop.
