Calculate solar radiation - 3D feature
1490
01-09-2020 05:23 AM
ArshaAmiranti
I'm using calculate solar radiation package in ArcGIS Pro.
I wonder which tool is it in toolbox?  Because I'm trying to run the package using my own data, but it is not working and returns error.
Thank you in advance
XanderBakker
Esri Esteemed Contributor
Hi Arsha Amiranti ,
Can you share what error you are receiving and describe what information you are using?
Where did you install the package? See also this thread:Calculate Solar Radiation | ArcGIS for Local Government to my 3D Geometry
ArshaAmiranti
Hi Xander Bakker
Sorry for my late response. I can't reproduce the error that I encountered. But I solved it by importing my multipatch into existed geodatabase provided by the ready-to-use tool.
I wonder whether there are any further/deeper explanation about this tool. Help section for example?
XanderBakker
Hi Arsha Amiranti ,
Apart from the get started section of the solution: Get started overview - Calculate Solar Radiation | ArcGIS Solutions for Local Government  and the related solution Get started overview - Local Government 3D Basemaps | ArcGIS Solutions for Local Government you could have a look at the tool in ArcGIS Pro that is used to calculate the solar radiation in ArcGIS Pro: Area Solar Radiation—Help | ArcGIS Desktop
ArshaAmiranti
How to see which tool that is exactly being used for each step? I want to visualize the result of solar radiation on my multipatch.
