Attribute Assistant: Using Joined Data in Nearest_Feature_Attribute method
1624
11-28-2017 10:25 AM
JoeBorgione
I am trying to update a new point feature with data joined to an underlying polygon feature class.
Background: The polygon feature class has the geometry of city boundaries and resides within an SDE feature dataset. The joined table right now resides in my local c:\ drive, and contains two additional fields that I need for the attribute assistant application.
When I initially tested the join in AA, it failed and I figured it did because I referred to the alias field name in the DynamicValue table:
(Both the 'ESN' and CommunityCD fields are from the joined table.)  However, after making the change, the logfile complains that it cant find the field name:
Row Info
   Row Number 17
   TableName: MasterStreetNameFC
   FieldName:
   ValueInfo:    slcopub.SLCO.Municipalities|ESN_CommunityTable.ESN,CommunityCD,ESN_CommunityTable.CommunityCD|ESN,   ZipJurs,CityJurs
   ValueMethod: NEAREST_FEATURE_ATTRIBUTES
   On Create: 1
   On Change: 0
Checking for Subtype Restriction
Field is not specified, empty, or set for all.
            Trying: NEAREST_FEATURE_ATTRIBUTES
            WARNING: search distance as not specified, defaulting to 0
            Looking for layer: slcopub.SLCO.Municipalities
            slcopub.SLCO.Municipalities layer Found: slcopub.SLCO.Municipalities
            Checking Field Mapping
            ERROR: Cant find field ESN_CommunityTable.ESN in table slcopub.SLCO.Municipalities
            Finished: NEAREST_FEATURE_ATTRIBUTES
Perhaps another set of eyes can see what I'm not; is it a path problem to the SDE/feature dataset,?
mmiller-esristaff
jmward
That should just about do it....
MikeMillerGIS
Esri Frequent Contributor
Does not work with joined fields
MikeMillerGIS
Could you make a database view to join those tables so it appears as a single table to the AA?
JoeBorgione
I'll give that a shot.  Thanks!
