Attribute Assistant - Underlying DBMS error
3432
09-24-2015 09:42 PM
MarkTurnbull
HI AA Gurus
I was wondering if there is any way to debug the following error from the AA logs, any further?
      Row Info
        Row Number 1
        TableName: Feature
        FieldName: Active
        ValueInfo: Inspection|ActiveFlag|GlobalID|Feature_GlobalID
        ValueMethod: UPDATE_LINKED_RECORD
        On Create: False
        On Change: True
      Checking for Subtype Restriction
      Field Name: Active was found at index: 5
                  Trying: UPDATE_LINKED_RECORD
                  Getting Value Info
                  Checking values
                  Checking Field in Edited Layer
                  Checking for related record
                  ERROR: UPDATE_LINKED_RECORD
Underlying DBMS error [[Microsoft][SQL Server Native Client 11.0]Syntax error, permission violation, or other nonspecific error] [GDLGISINS2.GIS_ADMIN.Inspection]
                  Finished: UPDATE_LINKED_RECORD
Mark
MarkTurnbull
A month later and no response on this one.
I have tried to trace the SQLs being generated with Profiler but cant seem to locate the query causing the Underlying DBMS error.
Through trial and error, I have been able to narrow the issue down to AA having some issue with using the globalid field as the primary key field. Can anyone tell me if this problem is likely to be caused by the differing data types of the key fields?
Mark
