Attribute Assistant - MOD Operator for Address Parity
3510
6
07-28-2022 11:26 AM
JasonBalmut
I am trying to calculate values for my NENA NextGen 9-1-1 parity fields by using the VBScript MOD operator.  The results should be (E)ven, (O)dd, (Z)ero, or (B)oth.  Here's what I have so far, although I do not get results with the ValueInfo expressions I have listed.  I'm unsure if this is a problem with the parentheses or the MOD operator itself.
Left Parity
  • TableName: MasterStreetName
  • FieldName: Parity_L
  • ValueMethod: EXPRESSION
  • ValueInfo (expressions tried):
    • IIF([FromAddr_L] MOD 2 = 0 and [ToAddr_L] MOD 2 = 0, "E", IIF([FromAddr_L] MOD 2 = 1 and [ToAddr_L] MOD 2 = 1, "O", IIF([FromAddr_L] = 0 and [ToAddr_L] = 0, "Z", "B")))
    • IIF(([FromAddr_L] MOD 2 = 0 and [ToAddr_L] MOD 2 = 0), "E", IIF(([FromAddr_L] MOD 2 = 1 and [ToAddr_L] MOD 2 = 1), "O", IIF(([FromAddr_L] = 0 and [ToAddr_L] = 0), "Z", "B")))
Right Parity
  • FieldName: Parity_R
    • IIF([FromAddr_R] MOD 2 = 0 and [ToAddr_R] MOD 2 = 0, "E", IIF([FromAddr_R] MOD 2 = 1 and [ToAddr_R] MOD 2 = 1, "O", IIF([FromAddr_R] = 0 and ToAddr_R] = 0, "Z", "B")))
    • IIF(([FromAddr_R] MOD 2 = 0 and [ToAddr_R] MOD 2 = 0), "E", IIF(([FromAddr_R] MOD 2 = 1 and [ToAddr_R] MOD 2 = 1), "O", IIF(([FromAddr_R] = 0 and ToAddr_R] = 0), "Z", "B")))
Any help is welcome.
Thank you.
JasonBalmut
The solution was to put the Zero part of the expression before the Odd/Even.  Here are the final expressions:
Left Parity
  • ValueInfo:
    • IIF([FromAddr_L] = 0 AND [ToAddr_L] = 0, "Z", IIF([FromAddr_L] MOD 2 = 0 AND [ToAddr_L] MOD 2 = 0, "E", IIF([FromAddr_L] MOD 2 = 1 AND [ToAddr_L] MOD 2 = 1, "O", "B")))
Right Parity
    • IIF([FromAddr_R] = 0 AND [ToAddr_R] = 0, "Z", IIF([FromAddr_R] MOD 2 = 0 AND [ToAddr_R] MOD 2 = 0, "E", IIF([FromAddr_R] MOD 2 = 1 AND [ToAddr_R] MOD 2 = 1, "O", "B")))
JoshSaad1
I do something similar, but using Arcade.  Here's my code:
Left Parity
var leftfrom = Boolean($feature.fromleft % 2)
var leftto = Boolean($feature.toleft % 2)
if($feature.fromleft == null || $feature.toleft == null) {
return null
else {
if($feature.fromleft == 0 && $feature.toleft == 0) {
return "Z"
else {
if(leftfrom == false && leftto == false) {
return "E"
if(leftfrom == true && leftto == true) {
return "O"
if(leftfrom == false && leftto == true) {
return "B"
if(leftfrom == true && leftto == false) {
return "B"
Right Parity
var rightfrom = Boolean($feature.fromright % 2)
var rightto = Boolean($feature.toright % 2)
if($feature.fromright == null || $feature.toright == null) {
return null
else {
if($feature.fromright == 0 && $feature.toright == 0) {
return "Z"
else {
if(rightfrom == false && rightto == false) {
return "E"
if(rightfrom == true && rightto == true) {
return "O"
if(rightfrom == false && rightto == true) {
return "B"
if(rightfrom == true && rightto == false) {
return "B"
It automatically applies the expressions as soon as you tab out from the address number fields.
JasonBalmut
@JoshSaad1 , we have to use ArcGIS Desktop's Attribute Assistant add-in for now and it does not use Arcade, it only uses VBScript.  I will keep your solution in mind for when we switch to Pro.
NormWray
Would you be willing to explain the "% 2" used in your function? I have run across this in several code blocks, but can't find it documented.
Thanks
JoshSaad1
I'm not a programmer, but from what I understand this is called a Modulo.  It determines whether there is a remainder when dividing one number by another.  Even numbers don't have remainders and return 0.  Odd numbers return 1.  The Boolean function interprets 1 as True, and 0 as False.
JasonBalmut
Update to the original post
The following expressions work for all cases except for zeros which results in (E)ven.  The ValueInfo lines are 168 characters each.
Left Parity
  • ValueInfo:
    • IIF([FromAddr_L] MOD 2 = 0 AND [ToAddr_L] MOD 2 = 0, "E", IIF([FromAddr_L] MOD 2 = 1 AND [ToAddr_L] MOD 2 = 1, "O", IIF([FromAddr_L] = 0 AND [ToAddr_L] = 0, "Z", "B")))
Right Parity
    • IIF([FromAddr_R] MOD 2 = 0 AND [ToAddr_R] MOD 2 = 0, "E", IIF([FromAddr_R] MOD 2 = 1 AND [ToAddr_R] MOD 2 = 1, "O", IIF([FromAddr_R] = 0 AND [ToAddr_R] = 0, "Z", "B")))
I have tried a few variations to get the zeros to work but haven't found one yet that is less than 255 characters.  The following two were tested but failed and each is 253 characters in length:
  • IIF(([FromAddr_L] > 0 AND [FromAddr_L] MOD 2 = 0) AND ([ToAddr_L] > 0 AND [ToAddr_L] MOD 2 = 0), "E", IIF([FromAddr_L] > 0 AND [FromAddr_L] MOD 2 = 1) AND ([ToAddr_L] > 0 AND [ToAddr_L] MOD 2 = 1), "O", IIF([FromAddr_L] = 0 AND [ToAddr_L] = 0, "Z", "B")
  • IIF(([FromAddr_R] > 0 AND [FromAddr_R] MOD 2 = 0) AND ([ToAddr_R] > 0 AND [ToAddr_R] MOD 2 = 0), "E", IIF([FromAddr_R] > 0 AND [FromAddr_R] MOD 2 = 1) AND ([ToAddr_R] > 0 AND [ToAddr_R] MOD 2 = 1), "O", IIF([FromAddr_R] = 0 AND [ToAddr_R] = 0, "Z", "B")
Suggestions?
JasonBalmut
Left Parity
  • ValueInfo:
Right Parity
