Attribute Assistant in the Enterprise GDB Enviroment... Again
2646
7
11-28-2016 09:31 AM
JoeBorgione
In https://community.esri.com/thread/185672-attribute-assistant-in-the-enterprise-gdb-enviroment  we all figured that the generate id table needs to be in the same enterprise geodatabase, but that the Dynamic Value table can reside in a separate file geodatabase.
I had my Dynamic Table rules working just great while testing everything (feature classes included) in a file geodatabase.  Now I've moved things into the enterprise environment and nothing gets updated as it has before.
Originally the 'Table Name' was CommonNamesSample, and resided in the same fgdb with the dynamic table.  I have the dynamic table in it's own FGDB and refer to the Table Name as:
database_name.OWNER.feature_class_name
I've also tried simply
feature_class_name
But haven't been able to get any of my rules to work.  Being the king of 'missing the obvious' I'm hoping someone can point me in the right direction....
mmiller-esristaff
AMuise-esristaff
jmward
That should just about do it....
MikeMillerGIS
Esri Frequent Contributor
Try just the table name and see what it says in the log.
MikeMillerGIS
Does the extension turn on? Does the button go green? If so, what is in the log? If not, what is the name of the dynamic value table into the TOC?
JoeBorgione
Extension is on: Check
Dynamic Table named accordingly: Check
Log Table:  I'll get back to you.  (Thanks!)
JoeBorgione
Michael- when I run the AA on the file GDB the logfile gets filled up with all sorts of info telling me what's going on.  However, this is the extent of the log file when I do the exact same thing (just add a point) in the enterprise database:
Edit Log Started at: 11/30/2016 1:32:56 PM
Process Count: 0
Unwiring the events
vecc2016.VECC.CommonNamesMaster - ON_CREATE
Starting AA
############ 11/30/2016 1:33:00 PM ################
  Setting sort order: Field - RUNORDER
  Querying table for Last Value for layer: vecc2016.VECC.CommonNamesMaster
  Query Used: (TABLENAME = '*' OR TABLENAME = 'CommonNamesMaster' OR TABLENAME like 'CommonNamesMaster|*' OR TABLENAME like 'CommonNamesMaster|%') AND VALUEMETHOD = 'Last_Value'
  Number of results: 0
  Querying table for rules for layer: vecc2016.VECC.CommonNamesMaster
  Query Used: (TABLENAME = '*' OR TABLENAME = 'CommonNamesMaster' OR TABLENAME like 'CommonNamesMaster|*' OR TABLENAME like 'CommonNamesMaster|%') AND ON_CREATE = 1
DONE
Wiring the events
Attribute Assistant is being suspended
Attribute Assistant is being turn off
Closing Log File 11/30/2016 1:33:10 PM
mmiller-esristaff
MikeMillerGIS
What is in the dynamic value table, vecc2016.VECC.CommonNamesMaster or CommonNamesMaster
JoeBorgione
Currently vecc2016.VECC.CommonNamesMaster, as mentioned in my op, I started out with CommonNamesMaster.  When that didn't work I figured I need the full database name and changed it.
MikeMillerGIS
JoeBorgione
I've used just the table name as per your suggestion and a few but not all of my DynamicValue table rules are working and show up in the log.  I'll give it my best shot to iron out why things aren't working at 100%.
As always, thanks for your help-
mmiller-esristaff
