WMS problem: works in ArcCatalog but not in ArcMap
2623
01-07-2011 06:05 AM
CoreyStaver
I have successfully used WMS before but something has gone wrong.  I can create a WMS connection in ArcCatalog and am able to connect successfully and see the images in the preview pane.  But when I try to add the layer to an ArcMap project I get this error "Could not add specified data object to map".
I tried adding the layer by using the Add Data button in ArcMap.  When I navigated to the connection it is shown with a red X as being disconnected.  And upon trying to access the connnection I get the error message "Generic server error message".
Here is one of the URLs if it helps:  http://maps.unr.edu/mapserver/services/Imagery/NAIP_NV/MapServer/WMSServer?
This is a URL that I have used successfully before.  And it seems that ArcCatalog is still able to connect.  Any ideas what's going on here?
AitorCalero_García
What version of ArcGIS are you using?
The URL http://maps.unr.edu/mapserver/services/Imagery/NAIP_NV/MapServer/WMSServer?request=getCapabilities seems to work well.
Have you tried with ArcGIS Explorer or any other client?
I would also suggest to use Fiddler to capture the requests/responses from ArcGIS.
Hope this helps.
