Using fixed spatial refrence system in ArcMap
2303
05-31-2012 01:14 AM
BasisGISEntwicklung
I´m trying to use a fixed spatial reference system for a Web Map Service in ArcMap (UTM32N).
How do I define this parameter in the GetMap URL?
I want to avoid the subsequent data-transformation, because the layer is used in a specialized application that loads the data in new mxd´s at run time,
the transformation is not performed.
In the WMS layer file the SRS information will not be saved ...
When using the GetMap-parameters in ArcCatalog the service returns all the capabilties and then uses the first SRS, which provides the WMS server.
Has anybody an idea to solve this problem?
Best regards
YingqiTang
Are you trying access the WMS with that particular projection through ArcMap, or simply through browser?
Thanks
Best regards
