Creating an ogc Spatial filter
6095
09-25-2012 08:03 PM
JosephShanahan
I an using Data Interop and and have added a WFS service.
I want to know how to implement a spatial filter. Got a literal one going easy enough but the spatial one is a problem.
I have started with this one. Just return all of the polylines within a given distance
I get a message the "DataSet appears to be invalid".
One of the things that confuses me is what do I insert for PropertyName. Is it geometry, SHAPE, polygon etc
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc xmlns:gml="http://www.opengis.net/gml xmlns:wfs="http://www.opengis.net/wfs">
<ogc:DWithin><ogc:PropertyName>Polygon</ogc:PropertyName><gml:Point>
      <gml:pos>152.540349 -32.444276</gml:pos></gml:Point><ogc:Distance> ogc:units='m'>60000</ogc:Distance>
      </ogc:DWithin>
</ogc:Filter>
Advancing form this then I shall need to construct a spatial filter to return all of the features inside a feature polygon.
I tried the following and got the same results
<ogc:Within><ogc:PropertyName>Geometry</ogc:PropertyName>
<gml:Polygon srsName="LL-GDA94">
<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>145.27626508549,-38.2022631817624 145.306722186365,-38.2003596129578 145.315526192086,-38.211067187484 145.314098515483,-38.2286751989272 145.292921312531,-38.2201091393061 145.27626508549,-38.2022631817624</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>
</gml:Polygon>
</ogc:Within>
</ogc:Filter>
Any help appreciated as there is not anything I can get a handle on to get this going.
PS: i don't know how to stop all of those smiles appearing in the xml
Regards
Joseph Shanahan
Esri Australia.
BruceHarold
Esri Frequent Contributor
Hi
We'll take a look but in the meantime here is an alternate approach.
Regards
MelitaKennedy
Esri Notable Contributor
Hi Joseph,
Try wrapping the XML with CODE tags. If you have "standard editor" set, it's a hash (#) button.
      </ogc:DWithin>
</ogc:Filter>
Or, this appears to work too, at least when previewing the post. In the "Additional Options", check on "Disable smilies in text".
      </ogc:DWithin>
</ogc:Filter>
Hope this helps,
Melita
JosephShanahan
I did post one issue, I had forgotten to close off the namespaces with a "
Latest posted one is correct but I still have the same issues.
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml" xmlns:wfs="http://www.opengis.net/wfs">
<ogc:Intersects>
<ogc:PropertyName>GEOMETRY</ogc:PropertyName>
</gml:Polygon>
</ogc:Intersects>
</ogc:Filter>
An answer to the following might make it clearer
should the line be
or
<ogc:PropertyName>SHAPE</ogc:PropertyName>
or
<ogc:PropertyName>SHAPE*</ogc:PropertyName>
or something else.
I have it working for a straight non spatial filter and I just inserted the name of the field.
Regards
Joseph Shanahan
JosephShanahan
I tried a lot of things to get this to go and I'm not sure which one eventually got it.
When you create a connection using data interop it is created in
C:\Users\jshanahan\AppData\Roaming\Safe Software\Interoperability
I moved the connection to a unc shared directory
Another is to be carefully to get the latitude and and longitude in the correct order.
I had them the wrong way around.
If you look in the capabilities file it will tell you the correct way to set them.
- <ows:Constraint name="serviceAxisOrderForSwappableSRS">
  <ows:Value>latitude,longitude</ows:Value>
  </ows:Constraint>
Also when you get a problem it is good to look in the server logs, they will tell you a lot.
Here is a sample filter that works
<ogc:Overlaps>
  <ogc:PropertyName>shape</ogc:PropertyName>
  <gml:Polygon srsName="EPSG:4283">
<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>-30.639482384733,132.012620960283 -35.2080475159278,156.568658540454 -41.7753598920203,154.427143635207 -42.7747335144692,150.572416805761 -30.639482384733,132.012620960283</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>
    </gml:Polygon>
</ogc:Overlaps>
</ogc:Filter>
Regards
Joseph Shanahan
