Unnamed error with Optimized Hot Spot Analysis, v 10.5.1
1531
10-14-2018 08:22 PM
StephanieDuce1
I am trying to run an Optimized Hot Spot Analysis in ArcMap version 10.5.1. This tool worked for me a couple of weeks ago but now there is an error icon next to the Input Features (screen shot attached) and no matter what input layer I select (projected/unprojected/shapefile/feature class etc.) the error does not go away. It doesn't provide details about what the error is when you hover or click the icon.
If I ignore the error and set the tool up to run as usual it gives the below error message with no details.
Am I missing something obvious? Is version 10.5.1 no longer supporting this tool or something? Is it time for me to upgrade?
Any help would be appreciated.
Steph
Tags (1)
DanPatterson_Retired
If it has worked in the past with the same or similar data, perhaps something has gone bad with your install.
From Windows Install/Remove programs, try a 'Repair' of the installation to see if that fixes it.
If not, you may need to 'reset your application profile'
last step would be an upgrade
bradenmiller
Having the same issue w 10.4.1.  I've run service packs, the install / repair, etc.  Nothing helps.
Windows 7 64-bit.
