Spatial weight matrix error
7700
9
05-20-2016 03:24 AM
GlynisHumphrey
Hi there,
I'm using the hot spot analysis to assess clustering/dispersion of of hot and cold fire spots and have generated a spatial weights matrix (.swm), however my weight column indicates the distance between points as 1 for all the point features. Please note I am using a projected data.
Any comments as to why, and how to trouble shoot this issue would be most appreciated.
Thanks in advance.
DanPatterson_Retired
Well...from the help file
At the most basic level, there are two strategies for creating weights to quantify the relationships among data features: binary or variable weighting. For binary strategies (fixed distance, K nearest neighbors, Delaunay Triangulation, contiguity, or space-time window) a feature is either a neighbor (1) or it is not (0).
From here
Generate Spatial Weights Matrix—Help | ArcGIS for Desktop what options did you use.
How Generate Spatial Weights Matrix works—Help | ArcGIS for Desktop
or were you using something else?
Do you want this directed to the Spatial Statistics or Spatial Analysis place?
GlynisHumphrey
Yes, I'm using the links you provided.  Please could you direct this question to the spatial statistics/spatial analysis group.
Thanks.
What were the parameters used?  This has a large impact on results.
And you are absolutely sure that you have a projected file.
An image would help as well of the area and the table
GlynisHumphrey
Yes, projected data. Please see image of spreadsheet below and output of (.swm).
Parameters used: Fixed_Distance /Euclidean
Threshold distance of 4500 m (decision based on the output of ''calculate distance band from neighbor'' (based on 8 neighbours).
OBJECT_IDNorthingEastingFRPUNIQUE1_ID
18000825,818511676948,7419901501
28000480,308070678427,6840792362
38000721,842627676206,7598891653
48000375,425250677791,5546511364
58001061,488425675362,908257885
68002041,327851677171,487260636
78015891,633053615645,426354367
88004444,952169692229,313859288
98015547,751748617655,792684259
108015775,358381616597,9881872210
118001356,018412679494,3576705411
128015775,358381616597,9881872212
138015547,751748617655,7926842513
148004444,952169692229,3138592814
Field1UNIQUE1_IDNIDWEIGHT
079458181
07945134431
07945111071
0794537211
0794579611
07945111041
07945111081
0794579841
07961111071
07961134431
0796158751
0796137211
079618331
Thanks Dan.
GlynisHumphrey
Many thanks Dan. I was concerned as all the feature points have neighbours in that case - as there are no 0. Will double check.
You might want to check your threshold distance then or try another model.  Post a map of your distribution if you want.
Glynis, could you mark this question by checking the answer that worked, or assumed answered or convert to a discussion.  Threads with closure indicate the status and are useful to others when looking for help on similar topics.
GlynisHumphrey
Hi Dan - thanks. Here is the distribution map - succeeded in generating a .swm - I verified my data based on a re-run of my data in GeoDa software and the same patterns emerge. Thanks for you help.
