Spatial Statistics Toolboxes Input Field has "X"
1986
09-20-2020 12:15 AM
TravisPeterson
I have a esri home use license. It is ArcGIS Advanced, so I thought I should be able to use the tool. I am using ArcGIS 10.4.1 Desktop. I am trying to run spatial statistics tools and the input field has a "X" and the tool does not run. Screen Grab Attached.
Any ideas on why I would receive this message.
TravisPeterson
  • Desktop Advanced includes spatial statistics.
  • Renamed Normal.mxt No resolution.
  • Ran Repair Installation No resolution.
  • Uninstalled Anaconda x64 and now the Spatial Statistics Tools work again. I don't know why this worked. I guess it might have to do with Python 2.7 which is used by 10.4.1.
DanPatterson
MVP Esteemed Contributor
Can we assume that you toggle on the extension?  (Customize, Extensions check on the extension)
Now, it will have an X until you navigate to a featureclass on disk.  So locate your geodatabase and select an appropriate featureclass.... or locate the folder containing your shapefile... whatever the case is
... sort of retired...
TravisPeterson
