Spatial Statistics/Analysis Toolboxes Not Working Anymore
1284
04-14-2013 08:55 AM
BarryJaggernauth
Hi Folks
I'm getting a problem with both the Spatial Statistics and Spatial Analysis Toolboxes/Tools.
Every time I run a tool, I get the following error:
Running script CollectEvents...
<type 'exceptions.SyntaxError'>: invalid syntax (_import_tools.py, line 263)
Failed to execute (Collect Events).
This is the first time that I've used the above tools in about 4 months, however, prior to that, I never experienced any problems.
I know it's not the data because I have tested this on my data as well as esri tutorial data, both end up with the same failure.
Please, I would really appreciate it if anyone can help me here.
Barry
(Using ArcGIS 10 sp4 on Windows 7 Pro 64 bit)
BarryJaggernauth
Problem solved!
1. There were two installations of Python which caused the confusion. I just removed the 3.2 version and went back to 2.6.
2. Reverted from IE10 to IE9
Everything seems to be working now.
Hope this helps someone who may have had the same or similar problem.
Regards
Barry
BarryJaggernauth
Problem solved!
Regards
Barry
