Space Time Cube not working
9394
14
05-12-2015 06:11 PM
JohnWarden
I'm trying to run the Create Space Time Cube script but it fails. The error message in the geoprocessing results message is:
File "<string>", line 372, in execute
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcToolBoc\Scripts\SSCube.py, line 1262, in_init_
   cubeStr,cubeFactor=UTILS.distanceUnitInfo[self.x.units.upper()]
KeyError: u'MILE'
Failed to execute (CreateSpaceTimeCube)
I have a point dataset of 10,500 records that are projected, with a date field. I extracted about 800 of these and tried running on a smaller dataset but that produced the same error message. I downloaded and installed the required patch for this tool before I tried to run it the first time.
I input required parameters and also let the program define all the optional parameters, but I always get the same result.
Any suggestions?
JohnWarden
Tech Support identified the projection as the problem. I was using Albers Equal Area with miles as the unit. Tech Support changed the projection to Web Mercator Sphere with meters as the unit and it works.
JenoraD_Acosta
I'm glad they got it figured out for you!
We found a typo in the code that handles projection conversion.  The majority use meters and feet and it turns out we didn't have a test for miles and we missed it.  Good catch and apologies for the inconvenience... we have fixed this for future releases.
-Jenora
SepheFox
Oh, so mile should have been miles?
JenoraD_Acosta
Mmmm... not quite exactly, but a letter S was definitely the problem
JohnWarden
Many thanks to all for their input...and especially to Jenora for a very timely response and resolution.
